Hi, i have following system in the screenshot and when i turning it on there is a BIOS message "CPU fan error" and i noticed the cooler fans (H100i cooler) is working in full speed and RGB lights on cooler fans and casing fans are not working but the fans works. Then i set up fans speeds to ignore and booted the system and noticed CPU temperature is below the normal (usually its 42-45 C) now its 29-35 that might be because the fans run in full speed.
I tried resetting BIOS and updating BIOS but its not working still. Should it be a problem wit the cooler? or Motherboard? as the RGB lights of casing also not working its hard to guess for me.
