Hi guys,
New to this forum etc hope I can get some help from some more experienced folk
Had my first build yesterday, put it all together and afterwards booted up, installed windows and restarted.
Got the "CPU FAN ERROR" and after I let it running I got a "CPU OVERHEATING ERROR too"
Checking the EFI it showed the CPU fan speed to be N/A then changed to ranging about 180rpm -222rpm (the bar was red)
It also showed the CPU temperatures to be at 71 degrees Celsius and increased till the bar was red.
Here were the specs:
- i7-3930k
- Asus P9x79 WS
- Corsair H100 Water Cooler
- 4x4gb Mushkin cl7 1600mhz (Which shows up as 1333mhz but that will be another issue for another time :[ )
- Corsair 800D case
- FSP Aurum 1200w psu
The rest won't matter I think. Anyway, I do believe I installed the H100 properly, ALL fans are running at what appears to be at appropriate speeds.
I've looked all over the internet about this issue and it's common BUT people don't get the CPU Overheating error too
ANY help would be appreciated as this is rather urgent and I need to get it all set up and installed to do uni work.
If anyone has a similar/same setup and could take photos of the plugs going wherever, that would be great!
THanks guys
- i7-3930k
- Asus P9x79 WS
- Corsair 800D case
THanks guys
