Hello,
I assembled my new pc 2 months ago and whenever i switched it on i used to get a msg 'CPU fan error". I ignored it because my pc used to boot up fine.
But once i put a password on my BIOS and i tried to clear it by opening my cabinet.
here is what i did-->
there was something called ClearRTC on my motherboard i changed it from 1-2 to 2-3.(1-2 said normal and 2-3 said ClearRTC).After this i switched on my computer. It didnt switch on(Though the fans were running).Then again i opened my cabinet and changed clearRTC back to 1-2(normal).Then though my password didnt clear something else happened. I put in the password and then along with the CPU Fan error msg another msg was displayed--press f1 for setup.When i pressed f1 i was directed to the bios. I exited the bios and once again switched on my comp. But again the same msgs were displayed. So i went to the bios again and i had to manually boot up my harddrive.Now whenever i nedd my comp i need to manually boot up my harddrive.IDK what the problem is.Did i damage the hardware becuz of ESD??
please Help
Thnx.
please Help
Thnx.
