cpu fan error
gerrymc
17
have just built a gaming pc z87 sabertooth mobo dark rock 2 cooler when I powered it up it comes up cpu fan error its plugged into correct slot in bios its red highlighted running at 500 rpm cpu temp 78 degrees is something wrong here hlp plz 🙁
yes it running 80 degree on idle
That is drastically out of whack! Should be 28* to 32*C.
Something is wrong with your cooler installation. I suggest that you remove the cooler, clean it well with rubbing alcohol and a lint free cloth or coffee filter. Do the same cleaning to the CPU. Apply new thermal paste and reinstall the cooler making sure that it is properly fitted and making good contact with CPU.
Yogi
Yogi
