hi guys
i just restored my os on my pc and now my cpu fan keeps running at 4000+ rpm at all times
it makes a weird sound which I assume is because it's spinning at such a fast rpm speed
i tried to set the CPU fan speed from the smartfan 5 program in the gigabyte bios to silent but it keeps running at same speeds as if nothing has changed. i tried to change the interval to 3, switched it from auto to pwm and even to voltage - still no difference
the setup is:
gigabyte z390 aorus pro
intel core i7-9700k
corsair h115i platinum
asus strix 1080 ti
corsair vengeance 3200 mhz 16 gb ram
corsair rm750x
anyone that might know a fix to this? the sound itself is not loud at all and the pc is functioning as it always did and temps are still in the low 30s but idk whether its good for the cpu fan to keep running at 4000+ rpm
thanks in advance
the setup is:
intel core i7-9700k
asus strix 1080 ti
corsair rm750x
thanks in advance
