Cpu fan not working
GFearless
Commendable
Nov 30, 2016
19
I just build my new. I start it the 2 fan of the case work my cpu fan dont work. As i see is connected to motherboard where is saying cpu fan. Is stock fan Amd fx 6300 help anyone? Did i forget any wire to plug ?
Alao my gtx1050ti fan not spining helo pls
Hi
Are there any messages on the screen about lack of cpu fan and gpu pci-e power cables
Or has it failed to start?
Many motherboards will not power up without a cpu fan
Check cable for cpu fan has not jamed the cpu fan blades
It should difficult to insert cpu fan plug the wrong way round but double check anyway
Regards
Mike Barnes
Latest posts
