CPU fan on radiator ramps up
AnObeseGiraffe
20
Whenever I am playing a game for example GTA 5 for about 4-5 hours and the cpu gets to 60 degrees celcius the cpu fan on the radiator ramps all the way to 11 is seems like and yet I have the fan curve to have it on the LOWEST rpm what is the problem here?
yeah i ended up doing it in the bios as well
but one thing i noticed if i run the asrock control software at startup to use features in it
it also has the ability to over ride what i set in the bios with out telling you it has
though no idea if msi boards have like a control centre software and if so if you are using it
but in the bios did you do a preset option--like silent/normal/full etc
or did you do a custom curve?
@mcnumpty23 the msi board comes with a custom curve that I have set to the lowest but have attempted to create a "normal" curve but had the same issue at 60 degrees its like its not listening to me.
