Hey, I got a new PC some time ago and ever since the beggining, the CPU fan made way too much noise. So i lookes it up in HWiNFO and it says, that the fan is going on about 1750 rpm constantly, which is making a lot of noise. It does so even when I am not running any CPU demanding applications, when the CPU temp is about 30 C. I belive I have connected it right (check: https://imgur.com/a/CifgMdG).
My relevant specs are:
Mobo: asrock ab350 pro4
CPU: AMD Ryzen 5 1600
Cooler: stock Wraith cooler
Thanks for any help, I've already asked on Reddit and noone was able to figure it out, so hopefully you will
