I recently installed an Athlon II X4 640 - 3.0 Ghz AM3 CPU into an M4N78 SE mobo, and I've been having overheating issues when playing CPU intensive games.
At first I thought I applied the thermal paste bad, so I took it out and spent a long time cleaning CPU and heatsink to a shine.
Then I followed online guides and put the thermal paste on using the pea method rather than spread. This method is supposed to stop air bubbles forming.
This did lower average temps by a few degrees, but it still overheated when playing games.
Then I noticed my fans speed would never go much above 975.
I have SpeedFan installed for monitoring temps and fan speeds. I have Cool'n'Quiet enabled in the bios. Cool'n'Quiet definitely did lower temps and bring the crash rate down.
I went through the whole process of enabling automatic fan speed control based on temps, following an online guide, but the RPM still stays around 975.
I then went into the BIOS and enabled Smart Q-Fan and set it to put fan at 100% when temps reach 51c. But still no change in fan speed.
All my fans do seem to rev up at boot up though, so I don't think they are broken.
But it does seem the fact the CPU fan won;t speed up in accordance with the temp is causing the overheating.
Any ideas??
I have been thinking maybe uninstalling SpeedFan?
Any ideas??
