CPU Fan stopped spinning
34
Hey! So my CPU fan which is the fan the cpu cooler came with (Be quiet! Rock 4) made this whine sound then stopped spinning then it started, and then I restarted my computer and it seems to be spinning just fine now. is this bad? do I need to replace the CPU fan?
Ok thanks! But is the whine noise it makes normal? Or could it be my gpu?
