Cpu help
tysonb
33
i reacently bought an i5 ivy bridge for my computer but when i put it in the computer wont boot up, pl
ease help
That's the way it should be. You need to navigate the the DOS folder on the disk now.
Unless you just copied the files directly from the DOS folder to the USB drive. In that case, just type BIOS_DOS.bat and hit enter.
Edit: The above needs the ROM folder copied over too, but if you copied all the folders over, that's not a problem.
Yeah, by navigate, I meant type. Just another way of saying it. Just copy over the whole BIOS_Gateway_P03.A2_Windows directory, and then go to the DOS folder after that. Should be something like "CD BIOS_GATEWAY_P03.A2_WINDOWS" or if shortened something like "CD BIOS_GA~1" then "CD DOS".
Note: I'm not exactly sure what the shortened folder name would be.
Hmm, I really wish I could just be there to see what's going on to help you out, lol. It's hard to know exactly what the problem is here without seeing it. The Windows version of the update SHOULD have worked, but the DOS version almost certainly would. But then again, like I said earlier, I don't have any experience with updating a BIOS on an OEM system, so there might be something I'm not thinking of.
Getting around in DOS is a bit of a bear, if you haven't done it much. I can definitely understand that. My first computer was DOS only, so I used to be pretty good at it, but I haven't really used DOS for more than one or two things in years, so I'm a bit rusty myself, lol.
Ok, here we go. I've thought of a way to simplify everything. You already have the USB drive bootable and have booted it into DOS, so we're good there. Just copy the contents from the DOS directory directly to root of the USB drive. That takes navigating to the DOS folder out of the equation. Then copy the Rom folder over too. Copy actual folder and then just copy the Rom file directly to the root, the same way as you will with everything in the DOS folder. That makes sure that it can absolutely find the Rom file.
Once you boot into DOS, just run BIOS_DOS.bat from there (Should just be (Drive Letter):\BIOS_DOS.bat).
If that doesn't do it, I don't know what will.
When doing stuff like then and you're unfamiliar with the command line it's usually a good idea to print out, or at least write down, the instructions. It's a massive pain to need to reboot the computer twice if you forget exactly how something needs to be typed.
