Having some cpu package temp issues curious if I’m missing something.
Fresh startup. No programs running and the cpu is at idle 3% and sitting at 60-70c. I think that is too high but I could be wrong. I have clocked it down from the default 57x to 55x using the intel utility. When at 57x it idles closer to 90c.
I have fans at max speed always and pump at max speed.
I did a test today. I pulled the cpu block and cleaned off the thermal paste and put a fresh on it to see if that’s would resolve the issue. Sadly no change.
It is a custom build. And custom water loop.
Double radiator running 3 120’s each.
One rear exhaust.
Water goes from pump -> gpu -> cpu -> radiator -> radiator -> pump
Motherboard - ASUS ROG Maximus Z790 Dark Hero
CPU - Intel Core i9-14900KF - Core i9 14th Gen 24-Core
Ram - 64gb ddr5 6400
CPU block - CORSAIR XC7 RGB ELITE LCD CPU Water Block
Hopefully I answered everything that might be asked.
One rear exhaust.
