[Re-post, as my older thread got deleted because it contained two negligible swearwords that were only used to lighten up the mood in a funny way: apparently, commonly used curse words like that are shunned and frowned upon in a sinless, chaste and pure forum such as this].
You are correct, swearing and vulgarity are not allowed on the forums as per the rules of conduct posted in the stickies at the top of the forum. This is a family friendly site.
http://www.tomshardware.com/forum/id-2083474/read-forum-rules-styling-posts.html
Hi everybody.
I'm gonna keep this as short and clear as possible.
I built my gaming PC earlier this year (it's been working great so far and still IS), here are the specs:
Mobo: Asrock h97 anniversary
CPU: Intel core i5 4690
Gpu: NVIDIA gtx 970 MSI
RAM: Crucial ballistix sport 8gb
HDD: WD 1tb
Psu: Evga 650W GS gold
SSD: Samsung 850 evo 250GB
Case: Corsair 100R carbide series
Monitor: Benq 24 inches 1920x1080 LED
So my CPU's making a whirring/buzzing noise while under load (heavy gaming mostly). I've already experienced this on my old PC (which had an intel core 2 quad q6600) but at the time I blamed it on the old/outdated components.
Nonetheless, I'm sure that this problem is not related to the cpu fan itself (like bad mounting, moving screws, fan vibration or any of that stuff).
Additional information:
YES I'm using the stock cooler + stock cpu fan, because the CPU isn't overclockable anyway.
In addition, I mounted:
- two 120mm fans right above the CPU (one is a noctua NF-S12A, 4 pin; the other is the stock corsair fan that came with the case, 3 pin)
- and of course a 120mm fan on the back of the case (which is another noctua NF-S12A plugged into a 3 pin connector because I ran out of 4 pin connectors on my mobo haha and the fans are SUPER SILENT anyway, so no problem there).
All three of those case fans are close to the cpu (they practically "surround" it) and they all pull that nasty hot air OUT of the case. I like that negative pressure, because it keeps the components cool and the dust out of my case.
All components run relatively cool and even though my room is pretty stuffy and hot, the CPU never goes above 62 degrees celsius and the gtx970 is A REFRIGERATOR with its double twin frozr arctic fans.
SO,
my cpu's running perfectly fine BUT it makes that annoying (though low) buzzing sound, like a low-volume recording of a swarm of ants frying in a pan. It might be the pre-applied thermal paste on the heatsink that's slowly failing.
Nevertheless, I haven't noticed any performance drops yet.
Should I be worried?
Thanks in advance.
Hi everybody.
HDD: WD 1tb
SO,
Thanks in advance.
