[SOLVED] CPU never reach target speed on OC
marthanaan
32
CPU Type QuadCore AMD Ryzen 3 2200G, 3755 MHz (37.5 x 100)
Motherboard Name ASRock X370M Pro4
Motherboard Chipset AMD X370, AMD K17.1 FCH, AMD K17.1 IMC
System Memory 8123 MB
DIMM1: Corsair Vengeance LPX CMK4GX4M1A2400C16 4 GB DDR4-2400 DDR4 SDRAM (20-16-16-39 @ 1200 MHz) (19-16-16-39 @ 1200 MHz) (18-16-16-39 @ 1200 MHz) (17-16-16-39 @ 1200 MHz) (16-16-16-39 @ 1200 MHz) (15-15-15-37 @ 1126 MHz) (14-14-14-35 @ 1051 MHz) (13-13-13-32 @ 975 MHz) (12-12-12-30 @ 900 MHz) (11-11-11-27 @ 825 MHz) (10-10-10-25 @ 750 MHz) (9-9-9-22 @ 675 MHz)
DIMM2: Corsair Vengeance LPX CMK4GX4M1A2400C16 4 GB DDR4-2400 DDR4 SDRAM (20-16-16-39 @ 1200 MHz) (19-16-16-39 @ 1200 MHz) (18-16-16-39 @ 1200 MHz) (17-16-16-39 @ 1200 MHz) (16-16-16-39 @ 1200 MHz) (15-15-15-37 @ 1126 MHz) (14-14-14-35 @ 1051 MHz) (13-13-13-32 @ 975 MHz) (12-12-12-30 @ 900 MHz) (11-11-11-27 @ 825 MHz) (10-10-10-25 @ 750 MHz) (9-9-9-22 @ 675 MHz)
BIOS Type AMI (07/03/2019)
Communication Port Communications Port (COM1)
task manager ss
Idk why my cpu never reach the target I input on the bios, last time I input the target to 3.8 GHz but the clock speed roams around 3.75 GHz
DIMM2: Corsair Vengeance LPX CMK4GX4M1A2400C16 4 GB DDR4-2400 DDR4 SDRAM (20-16-16-39 @ 1200 MHz) (19-16-16-39 @ 1200 MHz) (18-16-16-39 @ 1200 MHz) (17-16-16-39 @ 1200...
task manager ss
Max boost speed for that CPU is 3.7GHz so everything over that is a bonus. Ryzen doesn't OC very much, only really golden samples can OC all cores above official boost speed for one core so you are already doing quite well if it can run all cores at 3.775GHz.
Results are also subject to good cooling, 80c+ will also throttle it down and prevent OC or boost to give it high voltages.
