My other system is a PIV 2.4c that I bought almost 3 years ago. I had it O/Ced 30% for most of that time using an ASUS P4P800 mb.
Yesterday when I tried to load my PC I got an error message on loadup (prior to windows) stating that O/C failed. I selected to continue to Windows using the default settings. Within 20 seconds, power/signal stopped for my monitor and keyboard. My case's power continued to be ok (e.g. DVD drive opened and closed no problem).
I discovered that a restart did not resolve the lack of signal to the monitor or keyboard (the keyboard lights flashed when I powered on, but then went dead). Since then, if I wait for a while (~20+ minutes) I can get it to load for 60 seconds before the problem kicks in. It locks up even in the BIOS and in Windows. Doesnt seem to matter what I'm doing. In the short time I'm able to access the BIOS, the clock speed is set to the default factory settings. In addition, I didn't spot anything noticably wrong in the settings.
My question is this: is this likely a power supply issue, a CPU issue (due to the O/C warning, or is it even a motherboard issue? I'm at a loss as to what to do. Thanks for any help. I'm desperate here.
