keenanfullbuster Honorable Feb 26, 2012 22 0 10,520 Feb 26, 2012 #1 Hello guys i have a i5 2500k should i change my cooling system when overclocking 3.3 to 3.5 ?
Solution mcnumpty23 Feb 26, 2012 stock cooler should be good for 4ghz to 4.2ghz range over that then get aftermarket cooler
sosofm Splendid Feb 25, 2009 3,910 13 25,165 Feb 26, 2012 #2 At 3.3 , 3.5 don't have to change the cooler. If you want to go higher must to change the cooler. Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 0 66,960 Feb 26, 2012 Solution #3 stock cooler should be good for 4ghz to 4.2ghz range over that then get aftermarket cooler Upvote 0 Downvote Solution
geofelt Titan Oct 9, 2006 55,388 4,563 174,240 Feb 26, 2012 #4 mcnumpty23 : stock cooler should be good for 4ghz to 4.2ghz range over that then get aftermarket cooler I agree^ To my mind a simple $30 cooler like a cm hyper212 or Xigmatek gaia is a good idea anyway. It will keep your pc quieter under load and let you oc higher. Backplate mount is easier and more secure too. Upvote 0 Downvote
keenanfullbuster Honorable Feb 26, 2012 22 0 10,520 Feb 27, 2012 #5 Thanks a lot guys ) Upvote 0 Downvote
amuffin Illustrious Jul 29, 2011 14,971 1 41,960 Feb 27, 2012 #6 Cooler Master Hyper 212+! Upvote 0 Downvote
keenanfullbuster Honorable Feb 26, 2012 22 0 10,520 Mar 26, 2012 #7 Best answer selected by keenanfullbuster. Upvote 0 Downvote
