I've been having an issue with the wife's computer. It's an old Athlon 1200.
It was fine on idle but as soon as you tried to run something, probable within 15 min it would shut off. I checked the cpu temp and it was around 60c I think. I checked the heat sink/fan. The fan was running fine but had alot of crud in it. So after unplugging it, I took the hs/fan off and cleaned it out. I then put it back on. Now the computer will only stay on 15-20 sec at the most.
I checked to make sure I had the hs/fan on properly and it is. I didn't reapply any thermal compound though. Should the cpu not run longer than that even if it had no fan/hs installed?
Just looking for ideas.
Also before it's mentioned, I'm building a new box to replace this, but I'd like to have the kids use this one if possible.
Thanks in advance,
Gary
Thanks in advance,
Gary
