Question CPU Overheating while playing Metro 2033 Redux
Jul 3, 2019
9
Hi everyone,
Recently I started playing Metro 2033 Redux and the cpu overheats causing the computer to shut down, anyone have this problem with this game?
I ran a stress test with 100% usage for 15min and the temp didn't go above 64ºC / 147F so I don't know what can I do to solve this
Spec:
Ryzen 5 2400g with Msi Core Frozr L
Are you using the integrated graphics or on a separate GPU ?
Try taking your PC's side panel off and pointing a fan into it and see if the problem continues. If it runs ok with the case open and a fan on it you have a case cooling issue...
If it still crashes you have something else going on...might need to re-seat your CPU cooler.
Reactions: Blatzvid
I have a separate GPU , RX Vega 56 and changed the thermal paste yesterday.
What I don't understand is why it didn't shutdown at the stress test but ingame it does...
My normal temp is between 60ºC and 70ºC , but with this game it goes to almost 90ºC and then shutdown
