I have the ASUS P6T Deluxe V2, i7 920, 6 gb tri channel ocz gold ddr3 1600. For whatever reason, in the motherboard bios it is only saying 4 gb of memory is available. I have tried two of these motherboards and I keep getting the same results. I have tested each stick of memory in each slot, and the memory is not the problem. It is even on the supported memory list on the ASUS site. The problem seems to be the B slot the memory is in on the motherboard. It's is not reading the memory. Again I have tried two of these motherboards with the same results. I have checked for bent pins on both boards and that is not the case with either of them. Is it possible it is the CPU I am having a problem with, or have I just received two boards with the exact same problem?
Thank you.
My complete system:
i7 920 @ 3.2 ghz
6 gb ocz gold ddr3 1600
2 500 gig hd's in raid 0
2 4870's in crossfire
asus p6t deluxe v2
cooler master haf 932 full tower
1200w power supply
cooler master v8
windows 7 home premium 64
Thank you.
My complete system:
i7 920 @ 3.2 ghz
asus p6t deluxe v2
1200w power supply
cooler master v8
