CPU red LED
built2last
30
Here lately my computer has been going into sleep mode and not booting back on. After several attempts of powering on and off it boots back up. Does anyone have a solution to this or is my motherboard going out.
Finally found the blog page i was looking for (http://www.corsair.com/en-us/blog/2013/may/haswell-compatibility-with-corsair-power-supplies). Looks like the TX750M fully supports Haswell. However, this sounds exactly like a similar issue I had with my last power supply (CX750M). The CX750M is also supposed to be 100% Haswell compatible, but i had nothing but issues when it came to waking the computer up from sleep. Replacement unit that I received from Corsair had no issues at all with sleep states, so the first time around i had received a faulty unit.
If possible, test the system with a known good power supply that fully supports Haswell.
Yes! its a i5 4670k CPU
ASUS Z-87 MB
Corsair TX750M PSU
8GB of G skills ripjaw RAM
Sapphire R9 290x Tri-X GPU
Thanks! This solution worked
