Here are my Specs:
CPU: Ryzen 7 2700x
CPU cooler: Ryzen Wraith Cooler
Motherboard: MSI B450m Gaming Plus Bios (7B87v1H3(Beta version)
Ram: 32GB DDR4 corsair
SSD/HDD: 1TB NVME (windows location) 500GB SSD, 1TB HDD.
GPU: AMD Sapphire 7800xt 16gb
PSU:850wat Corsair (2 years old)
Chassis: Cyberpower
OS: Windows 10 (installed from USB with media creation tool on a separate PC)
Monitor: Samsung G5
So a few days ago I noticed my pc was acting extremely slow, rebooted and got an error message saying pc needs to be repaired. I then got an error code loop of error code 0xc0000221. I decided to wipe and fresh install windows 10. Booted it up after fresh install and it was still extremely slow. Checked cpu speed and it’s capped at .52ghz with no movement.
Decided to change power management settings in control panel and reboot and make sure all drivers and updates were good and nothing. Found a thread mentioning downloading Ryzen Master and turning off PROCHOT, did that and it worked but only if I turned off prochot.
Now that I’ve done that the PC is making the usb connection sound and all lights and supply shut off for about .5 second and come right back as if nothing happens and I’m still in windows. It happens every 20 Seconds or so and gradually gets quicker and quicker. Pretty confused about this, already took apart entire pc and reseated cpu and applied new paste but still nothing. The pc will keep on with that low speed but it’s extremely annoying and really slow.
I’m thinking it’s something with bios and speeds but I’d need help navigating that.
CPU: Ryzen 7 2700x
Chassis: Cyberpower
Monitor: Samsung G5
