[SOLVED] CPU suport for my motherboard.
Sep 13, 2020
8
Hello,
im planning to buy a new PC soon and im a bit confused about my motherboard.
My cpu is compadiable with my motherboard but it requires my motherboards BIOS to be updated. The update that the cpu needs is from May 2019. Would the motherboard be updated to the correct version when I buy it now?
CPU: AMD Ryzen 5 3600
Motherboard: Gigabyte B450-GAMING-X
Hello,
Depends how long MB was sitting on a shelf so you need to contact seller,
It needs BIOS at least version F40 which was released on May 16 2019 so any produced after that that date should have it. Compatibility is usually marked on the box.
https://www.gigabyte.com/Motherboard/B450-Gaming-X-rev-10/support#support-dl
Hello,
