I have a AMD A8 5500 cpu and MSI A55 E33 Mainbored. I mailny use the comp for downloading and watching 1080p movies but after putting up with the noise coming from the heatsink for the last 5 months its driving me crazy. I've had a look at coolers and decided on the cooler master hyper 212 evo but a few of the reviews said its good but is like a jet engine unless you lower the Rpm down, which i don't know how to do. So i tried lowering the stock coolers rpm in the UEFI first to see if that helped & how to do it. But when i change the speed nothing happens... If i were to buy the coolermaster heatsink would that allow me to change the speed? Or would i just be replacing the stock cooler for an even noisier heatsink?
My 2nd question is... I can't monitor my exact cpu temp as i cannot find a program that shows the correct temp with it been an APU but after 30mins on bios its showing 58c is this too hot? Plus i noticed when i use the comp for 3hrs playing about & then reboot the cpu temps on the bios when it first loads in is only about 38c? Why would my temps be lower multitasking rather than idle on the bios?
Any help/advice much appreciated
