mindlogiczero
136
motherboard is a m3A76-cm by asus, cpu is a amd atlon 7850+ am2+. in bios it shows temp as 30c. but in windows it shows, 11-14c. ive even updated bios to newest verison and it still shows same thing. any ideas on a possible fix so i can see temps from coretemp or something? its showed same low temp in core temp, hwmonitor, everest.
ulysses35
OK there is some confusion where the CPU temp is read from by windows based software.
Some measure it from the chip itself and some from a sensor just under the CPU socket...
I beleive there is also variance in some software itself
eg
Real Temp shows :-
CPU Temp
Core Temp
both showing different figures to what my BIOS says right now
