Hi,
I recently started my second computer build. My last one was 6 years ago. A lot of stuff changed and I'm feeling kinda noob.
I'm worried about my CPU temperature.
The temp is very unstable and varies constantly between 55~70ºc (on idle). When I start gaming it reaches up to 80ºc.
I'm new with liquid CPU coolers, but I wasn't expecting this kind of temperature.
I already changed the thermal compound but still got the same result.
My case is an NZXT h710i with the rad/aio at the top with 3x 120mm fans as exhaust, 140mm exhaust at the rear, and 3x 120mm as an intake at the front, all fans were replaced with Noctua fans.
My top fans are connected directly to the rad/aio, back and front are connected directly to the motherboard. (Initially, I had them connected to the NZXT fan controller)
My board has something called Q-FAN and has software called FAN Xpert 4. The only thing I did with these two was identifying all fans' positions and run the "fan tuning".
Here are some print screens of my current configuration inside my BIOS (the BIOS indicates that the temperature is ~47ºc):
This is a print screen of the software FAN Xpert 4 (this one indicates the same result as the Kraken z73 - labeled as CPU package):
This is my current build:
Case: NZXT h710i
CPU: AMD Ryzen 9 3900X
CPU Cooler: NZXT KRAKEN z73
Motherboard: Asus ROG STRIX B550-E
Memory: G.SKILL Trident Z 32GB 3600MHz CL14
Storage: Corsair MP600 1 TB
GPU: MSI 970
PSU: Corsair 1000W
FANS: Noctua NF-A12/A14 PWM
Questions:
1 - Is the CPU temperature normal (my last CPU was getting 40~45º on idle)?
2 - It varies 1º~10º constantly every second, is that normal?
3 - Should my fans be connected differently? Or do I need some kind of configuration?
4- How can I improve the CPU's temperature?
Case: NZXT h710i
GPU: MSI 970
PSU: Corsair 1000W
Questions:
