CPU temps Help
Kidd24
Seems like there's something wrong about my cpu temp guys, i changed my mobo reapplied thermal paste and clean my cpu and my stock fan but i got 50+ celsius on my bios and and when i use monitoring tools like Open Hardware i get 3 temps 1 from CPU core 1 which is like in bios 50+ C and Core 2 which is like my old temps 30+ C and CPU Package same as core 1 and bios can i ask why i get this temps whats the problem im worried about my temps when i play games can it affect the lifespan of my cpu ? my temps then are 30 - 39 idle 50-60 gaming so it's pretty far from normal i guess ?
This is the printscreen of open hardware
http://imgur.com/hKPGj9w
68c as temp with only 50 load on cpu that is a bit hot i would recheck cooler and fan on it also try hwinfo to get more readings from system .
your lifespan wont be shortened, unless you want to count the microseconds(no clue).
as long as your cpu temp stays under 85c max load youre fine, it doesnt amtteedr if its 80 or 65c.
youre just beeing paranoid, no worries.
but its good you keep an eye on your temperatures.
thanks dude i set my motherboard to shutdown itself incase it reached 85c im starting to save 5$ a week incase lol. thanks
