Yes.this pictured cooler above has it got liquid in it.
is this a good coolerRight.
An All In One. Sealed unit, not refillable.
I can vouch for this one - I have it.i seen some water coolers have a tank and some that does not have tank.
the ones that has no tank and its titled water cooler is the liquid already inside.
Both the liquid coolers you linked are full of RGB.oh sir i am not interested in led lights i got it because it was recommened to me and i ordered it, it's still not dispatched yet so maybe i can ask.
i dont care about led simple darkness is ok lol i am more into cpu and gpu system power.
the setup am building will that be strong and powerfull for use with adobe after effects ? if you say adobe after effects use one core than i can use rendergarden plugin that creates seperate instances of the same render file working together exporting it.
RenderGarden | Mekajiki
www.mekajiki.com
You needed to do a lot more research before buying parts.sir will this system be capable of handling 1080p and 4k projects with 128gb ddr4 nvme gen4 drive will it be fast?
OK, so Pro, Semi-Propremier pro + adobe after effects + c4d + 3d max + photoshop.
3d modelling
element 3d by video co-pilot
making long project wedding videos adding particles, transitions of all kinds.
motion fx particle illusion systems
mocha pro tracking.
will I see any lags as I move the slider-bar of preview
