Crashing, no info in dump. Some thing hardware
kyleremi
4
My computer is crashing and leaving no dump files in my kernel memory roots. When it crashes the screen goes black but is still illuminated. The sound blares various loud vibrating tones resembling the music or voice i was listening to. I then restart my computer and go random amounts of time between crashes. Some times it happens twice a week a day or a month. There does not seem to be a coloration between the load and the crashing either. I can run a stress test and pass with flying colors or have multiple high end games running at once.
I recently replaced my graphics card as the old crashing left my monitor with purple specked blocks distorting the previous image. I read this as an issue with my ram on the card so i replaced the entire card with an upgrade.
Current suspicions are:
The on board sound-card (really REALLY hope that is not it since it is attached to the board and would have to be melted off).
Insufficient cooling ( I am still using air cooling. 8 copper heat sinks and 2 large fans.)
Insufficient or faulty power supply. ( I am using a 880w atm and do not beleive my load exceeds that. I am considering replacing all the power dongles as i have plenty of all kinds just to see if some home there is a messed up wire.)
follow this
download ccleaner from thislink
http://www.mediafire.com/download.php?jtznxp8cx8bhhc9
install it only
donot run it
then download ccleaner enhancer from this link
http://www.mediafire.com/download.php?5j2bjxex8d5hb59
run it
and press download latest
then run ccleaner now
now
in
cleaning tab
check all selection in windows and application tab
except the selection of wipe free space in windows tab
press cean now button in the right side
after that go to registery tab and press search for
then press fix all selected
then
download antimalwarebyte from this link
http://www.mediafire.com/download.php?9sxsxuvk10v7ood
install it and run it then update it if it asked
then perform full scan to whole computer partitions from safe mode
and remove all threats
kylermi , have you done any overclocking ? The cpu , ram or video card ? When you have these crashes what are you doing at the time ? Gaming , surfing , do the crashes happen when you are doing the same thing or does it vary. I know you said it varies when you have the crashes but if it happens when your doing a specific task or not will help. I had a similar thing happen to me and it ended up being a defective bios chip on the motherboard. I sent it in to the manufacturer and they replaced it and the issue vanished.
