Crashing with audio loop / stuttering nonsense.
FinallyFedUp
4
So I have had this computer for a bit and it has had this problem for as long as I have owned it, and it had the problem when my friend owned the computer as well. The computer would at times just freeze up completely and then seems to loop whatever current sound its playing and requires a restart.
My friend gave me this PC for free because of this problem, and normally this problem would drive me as crazy as it did him. But for whatever reason when I run a game the problem doesnt occur. My solution is just to run a game (usually Torchlight) in the background while I do other things and it worked for a long time, still does.
Month or so back I fried my power supply, which all of my research on the problem led me to believe that the power supply was probably the source of my issue in the first place. I ordered the same power supply because I wasnt really sure what I was doing. May have been a bad idea if that was the reason it was fucked in the first place. http://www.newegg.com/Product/Product.aspx?Item=N82E16817148046 is the power supply in question.
What has lead me to finally ask people about the problem is I purchased Dishonored in the steam sale yesterday (woo!) but it likes to crash my video drivers (boo!). Im wondering if for whatever reason the graphics card might somehow be responsible for the issue. Dont really know. Basically I got some money to throw at this problem and get it fixed for good, the amount is enough to buy replacement parts but not enough to just buy a flat out better comp.
Not sure what all you need to know.
NVIDIA GeForce GTS 250 graphics card
Intel i5 750 2.67 processor
Ill put a CPU-z print out thing in my next post they seem pretty large and id rather not clutter this post any more.
Post might be too long had to cut out some things
CPU-Z TXT Report
Binaries
CPU-Z version 1.62.0
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 2.602 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 4 (max 16)
Name Intel Core i5 750
Codename Lynnfield
Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
Package (platform ID) Socket 1156 LGA (0x1)
CPUID 6.E.5
Extended CPUID 6.1E
Core Stepping B1
Technology 45 nm
TDP Limit 95 Watts
Core Speed 3172.5 MHz
Multiplier x FSB 24.0 x 132.2 MHz
Rated Bus speed 2379.4 MHz
Stock frequency 2666 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 4-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 8 MBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max turbo frequency 3200 MHz
Max non-turbo ratio 20x
Max turbo ratio 24x
Max efficiency ratio 9x
TDC Limit 89 Amps
Core TDP 89 Watts
Uncore TDP 6 Watts
Power @ 9x 14 Watts
Power @ 10x 17 Watts
Power @ 11x 20 Watts
Power @ 12x 25 Watts
Power @ 13x 30 Watts
Power @ 14x 36 Watts
Power @ 15x 43 Watts
Power @ 16x 51 Watts
Power @ 17x 60 Watts
Power @ 18x 70 Watts
Power @ 19x 82 Watts
Power @ 20x 95 Watts
Max bus number 63
Attached device PCI device at bus 63, device 2, function 1
Attached device PCI device at bus 63, device 3, function 4
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01020005h
Max CPUID level 0000000Bh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 16 thread(s)
CPUID
0x00000000 0x0000000B 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000106E5 0x00100800 0x0098E3FD 0xBFEBFBFF
0x00000002 0x55035A01 0x00F0B0E4 0x00000000 0x09CA212C
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x00C0003F 0x0000007F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x03C0003F 0x00001FFF 0x00000002
0x00000005 0x00000040 0x00000040 0x00000003 0x00001120
0x00000006 0x00000003 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300403 0x00000044 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x28100800
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x35692029 0x55504320 0x20202020 0x20202020
0x80000004 0x30353720 0x20402020 0x37362E32 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000005
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x00000900 0x40031400
MSR 0x00000017 0x00040000 0x00000000
MSR 0x00000035 0x00000000 0x00040004
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x15151818
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001AC 0x00000000 0x02C802F8
MSR 0x000001FC 0x00000000 0x00000001
MSR 0x00000300 0x00000000 0xF000000D
MSR 0x0000019C 0x00000000 0x882D0000
MSR 0x000001A2 0x00000000 0x00631000
MSR 0xC0000103 0x00000000 0x00000000
MSR 0x00000198 0x00000000 0x00000015
MSR 0x00000199 0x00000000 0x00000015
CPU Thread 1
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01020005h
CPUID
0x00000001 0x000106E5 0x02100800 0x0098E3FD 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000002
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x0000019C 0x00000000 0x88320000
CPU Thread 2
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 01020005h
CPUID
0x00000001 0x000106E5 0x04100800 0x0098E3FD 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000004
MSR 0x0000019C 0x00000000 0x88310000
CPU Thread 3
APIC ID 6
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 01020005h
CPUID
0x00000001 0x000106E5 0x06100800 0x0098E3FD 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000006
MSR 0x0000019C 0x00000000 0x88300000
Chipset
Northbridge Intel DMI Host Bridge rev. 11
Southbridge Intel P55 rev. 06
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 4096 MBytes
Channels Dual
Memory Frequency 660.9 MHz (2:10)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Row Refresh Cycle Time (tRFC) 74
Command Rate (CR) 1T
Uncore Frequency 2115.0 MHz
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) PQI CORP. (7F7F7F7F7F3E0000)
Size 2048 MBytes
Max bandwidth PC3-10700H (667 MHz)
Part number Q1040039
Manufacturing date Week 17/Year 10
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-16-22 @ 444 MHz
JEDEC #2 8.0-8-8-22-30 @ 592 MHz
JEDEC #3 9.0-9-9-24-33 @ 666 MHz
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP no
AMP no
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 92 05 0B 02 02 11 00 09 03 52 01 08 0C 00 34 00
10 6C 78 6C 30 6C 11 20 8C 70 03 3C 3C 00 F0 83 88
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 05 3E 08 10 17 00 00 00 00 A8 1A
80 51 31 30 34 30 30 33 39 FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF A4 21 19 42 50 10 0C A5 FF FF
DIMM # 2
SPD registers
F0 FF FF FF FF FF FF A4 21 19 59 50 3C 01 A5 FF FF
Monitoring
Mainboard Model P55M-UD2 (0x000001FF - 0x00A9EA2C)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8720
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8720
LPCIO Revision ID 0x8
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 20 08 00 00 00 FF 1D 40 00 00 00 81 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor ITE IT87
Voltage 0 1.25 Volts [0x4E] (CPU VCORE)
Voltage 1 1.60 Volts [0x64] (DDR)
Voltage 2 3.39 Volts [0xD4] (+3.3V)
Voltage 3 5.19 Volts [0xC1] (+5V)
Voltage 5 12.80 Volts [0xC8] (+12V)
Voltage 8 3.17 Volts [0xC6] (VBAT)
Temperature 0 37°C (98°F) [0x25] (PCH)
Temperature 1 25°C (77°F) [0x19] (CPU)
Fan 0 1421 RPM [0x1DB] (CPU)
Fan 1 1027 RPM [0x291] (FANIN1)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 13 10 50 00 FF FF 00 37 FF 87 60 0F 07 DA 90 FF
10 FF FF FF 72 D7 82 80 82 01 02 FF FF FF FF FF FF
20 4D 64 D4 C1 53 C8 09 86 C6 25 19 2C 80 C2 33 33
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 7F 7F 7F 7F 7F 7F 5F 74 2D 40 95 00 FF FF FF FF
50 FF 38 7F 7F 7F D0 59 59 90 59 04 12 60 00 00 00
60 00 0A 37 23 90 03 00 FF 00 14 41 23 90 03 00 FF
70 00 0A 37 23 90 03 00 FF FF FF FF FF FF FF FF FF
80 00 00 00 00 00 00 00 00 02 30 01 02 01 00 20 E1
90 FF 00 00 00 FF 00 00 00 FF FF FF FF FF FF FF FF
A0 D3 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor Gigabyte DES
Voltage 0 1.25 Volts [0x4E] (CPU)
Current 0 22.04 Amps [0x9] (CPU)
Power 0 27.51 W (CPU)
DMI
DMI BIOS
vendor Award Software International, Inc.
version F6
date 11/23/2009
ROM size 2048 KB
DMI System Information
manufacturer Gigabyte Technology Co., Ltd.
product P55M-UD2
version unknown
serial unknown
UUID {00000000-0000-0000-0000-6CF0490FE359}
DMI Baseboard
vendor Gigabyte Technology Co., Ltd.
model P55M-UD2
revision x.x
serial unknown
DMI System Enclosure
chassis type Desktop
chassis serial unknown
DMI Processor
manufacturer Intel
model Intel(R) Core(TM) i5 CPU
clock speed 2800.0 MHz
FSB speed 133.0 MHz
multiplier 21.0x
DMI Memory Controller
correction 8-bit parity
Max module size 1024 MBytes
DMI Memory Module
designation A0
size 2048 MBytes (single bank)
DMI Memory Module
designation A1
DMI Memory Module
designation A2
DMI Memory Module
designation A3
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation SECONDARY IDE (internal)
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation COM2 (internal)
connector DB-9 male
DMI Port Connector
designation LPT1 (internal)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
designation No Detected (external)
port type Mouse Port
connector PS/2
connector PS/2
DMI Port Connector
designation USB (internal)
port type USB
connector Access Bus (USB)
DMI Port Connector
port type USB
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 32768 MBytes
max# of devices 4
DMI Memory Device
designation A0
format DIMM
type unknown
total width 2304 bits
data width 2252 bits
size 2048 MBytes
DMI Memory Device
designation A1
format DIMM
type unknown
DMI Memory Device
designation A2
format DIMM
type unknown
size 2048 MBytes
DMI Memory Device
designation A3
format DIMM
type unknown
Graphics
Number of adapters 1
Graphic APIs
API NVIDIA I/O
Display Adapters
Display adapter 0
Name NVIDIA GeForce GTS 250
Revision A2
Codename G92
Technology 65 nm
Memory size 1024 MB
Memory bus width 256 bits
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x0000)
Model ID 0x0615 (0x0000)
Performance Level 0
Software
Windows Version Microsoft Windows 7 (6.1) Home Premium Edition 64-bit Service Pack 1 (Build 7601)
DirectX Version 11.0
1. don't use inappropriate language. nobody likes reading it.
the PS may not be the best but the machine should run right with it.
shut down auto driver updates and shut down windows auto updates.
uninstall the nvidia drivers. reboot. install nvidia drivers but do a custom install. only install the graphics driver and the physx driver.....nothing else. reboot/play. what happens?
Tried the custom install, didnt see to have any effect on the freezing audio stutter problem, and have yet to test the crashing in Dishonored because its a bit more sporadic and havent had time. Will reply if it does anything for the Dishonored issue.
Edit: Tried dishonored, still has the driver crash. Said technical information 0x00000116 i think. Hope this helps identify the problem a bit.
