Okay.. so... I just upgraded from Crucial Ballistix 3000mHz to 3600mHz. however its caused a whirlwind of problems in my pc.
Asus TUF x570 gaming plus wifi
ryzen 5600x
2x8gb crucial ballistix
280 pro nvme
xfx gts rx580 black edition 8gb oc+
few storage drives
Ive read elsewhere that this motherboard is limited to about 3400mHz memory, however with a recent bios update it was mentioned that 3600mhz was now supported.
~tried manually setting the parameters of the memory 16-18-18-38 and 1.35v
![](/proxy.php?image=https%3A%2F%2Fi.ibb.co%2F2cSTnDz%2Fballistix-3600.jpg&hash=231816ce16840a4e8116d1a0392e729a)
host an image
this memory doesnt seem to want to sync.. any ideas?
as this is an AMD build... "XMP" is not an option in the bios. however the profile for it displays in bios when looking at the memory specifications.
ive had to reset my bios 5 times in total.. to even get to this point.. im somewhat stumped.. never had any of these problems with the 3000mHz chips..
ryzen 5600x
280 pro nvme
few storage drives
- took out my 3000mhz installed the 3600 into slots a2, b2 (these slots are the only ones with just 2 sticks of memory where xmp/docp can work when using only 2 sticks of memory.
- booted into bios no problems, however noticed that the memory was registered as 2666mhz. this is where i attempted to set the ram perameters manually as to not affect my overclock on my cpu (@ 4.7ghz).
- saved settings and reboot.. 1 long 2 short beeps, it power cycled 3 times like this, and then came back up, single beep, and Q-led on vga stays lit... black screen..
- pulled the cmos battery and flipped the dip switch on my psu for 5 mins to dissipate any residual power..
- booted back into bios. attempted to run the docp settings, where it wiped my overclock on cpu . reboot.. no video again..
- used a backup vid card i had got into bios. reset the bios for the TPM-safe computing. to descrete.
- installed my 580 again. got into bios, and just booted into windows, where i sit here typing this now..
host an image
