[SOLVED] Cryorig M9 plus vs Arctic Freezer 34 (esports) duo
Naipross
187
Which one of these 2 cooler gives better performance and wich one is quiter?
Also what's the difference between the Esports version and the regular version on the freezer 34?
The difference between an Arctic Freezer 34 and the Arctic 34 Esports is that the Esports looks better and comes with a better fan (Bionix), the Esports DUO comes with 2 Bionix fans.
I have the Arctic Esports 33 with 2 120 mm Bionix fans and it works very well on my OC'd Ryzen 5 2600.
Idle temps are around 27-30 depending on room temp and it maxes out around 55-56C after 3-4 hours of gaming.
The Cryorig M9 plus is a dual 92 mm fan version of the M9i so it should give you slightly better cooling that the M9i:
https://www.techpowerup.com/reviews/CRYORIG/M9i/6.html
