Crysis 3 running on dx10 card
pubudu senanayaka
How can i run crysis 3 on my nvidia 220gt card?I have seen on crysis 3's requirements that you can run it on dx10 cards.But when i try to run the game the game says that you need a dx11 card
WHen you say when you try to run the game, can you get to the main menu? If you can get there, it will be under the settings.
If you cant do that, then I would suggest borrowing a friends DX11 GPU and using that to change the in game settings, and then re-installing your own card.
But to be really brutal here, you could do with upgrading your GPU anyway. Crysis 3 just looks so much better in DX11 on high settings. =)
Actually, there is a DX10 patch out for Crysis 3 which is very easily obtainable via a simple Google search, and is even easier to install. =)
Cool - I wasn't aware of that unofficial patch
Well i searched in google but can't find a good patch.I have to complete surveys 🙁Can you tell me of a patch that really works?
I shall have to have a seach for it when I get home Im afraid, I cannot access those sort of sites due to the company internet policy. =P
I may have one at home, maybe, if i can find it Ill upload it somehwere for you to download. =)
If all else fails can you not get in touch with the file owner and ask for the password? Was there not a password listed on the site you downloaded it from?
AAh, I see. Sometimes people upload these things and forget to post a password. Or forget it. Lol XD
Like I say, I cannot looka t that file I linked you as I am at work and so I cannot access megafileupload, so I dont know if you need a password or what the size is. I wouldnt have thought you would need a password for that particular file though. Just download it and see? =)
I doubt Intel HD 3000 graphics will cut it im afraid, the minimum GPU requirement is an 8800GT whihc is about twice as powerful than the HD 3000. =( But that being said running it in DX10 might help. Although I wouldnt expect to get a great frame rate or be able to run at anything other than minimum settings. =/
If I find the DX10 patch I shall be sure to email it to you. =)
