[SOLVED] Crystal disk info total read/writes
CrystalDiskInfo has a Text Copy function which enables you to save the SMART data to a file. Otherwise use the PrintScreen key to capture your screen to the clipboard, or you could use the Windows Snipping Tool.
It appears that CrystalDiskInfo doesn't understand WD's vendor specific attributes, but that need not be a problem. We can probably decipher them … if we can see them all.
