Cs go fps
stavros_1908
Hello i have an issue.
When i play cs go,i have 40 fps and 70+ ping
When i try to alt+tab its freezing
My pc specs:
CPU: AMD FX-4300 4cores
Motherboard: ASrock 990FX E3
RAM: HyperX 4GB ddr3 1866mhz
GPU: GeForce GT 610 2GB ddr3
Cpu temp: 36 C ( i have hydro cooler=zalman)
OS: Win 7 64bit not activated
power supply: 950W
How can I increase my fps?
1) +8GB ram
2) buy another gpu?
http://prntscr.com/gicxt6 (cpu)
http://prntscr.com/gicypl (cpu)
http://prntscr.com/gicxx0 (ram)
http://prntscr.com/gicxzj (gpu)
http://prntscr.com/gicydt (gpu)
On which settings are you playing csgo?
If you dont play with all the Graphics settings set to the max you should get around 70 - 90 FPS
But still your Graphicscard is a bit old....
How much money would you want to spend?
I would recommend you to watch out for a new GPU
Something like a GTX 1050 would be more than enough!
Greetz
Greetz
Your gt 610 is simply put a potato. Upgrading it will increase your performance quite a bit.
