Question Csgo low fps on 750ti?
adrian523
29
Hi. What is the usual fps when playings csgo with 750 ti? And is it better than radeon r7 200 series?
AMD A8-6600k
Nvidia 750ti
16gb ram
Fps is running below 90fps and lowest possible is 40fps
Whats the usual fps on 750Ti? And is it better than radeon r7 200 series?
Amd a8-6600k
750 ti
16gb ram
Fps running below 100fps and low as 40fps. I have seen on youtube that they run their csgo more than 120fps.
Drivers are up to date too.
The 750Ti was geared towards eSports players and titles, and for entry level gaming. You may want to list your current system's specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
GPU:
PSU:
OS:
include the age of your PSU, not just the wattage and make/model.
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
GPU:
PSU:
OS:
CPU: AMD A8-6600K with Radeon HD Graphics (4 CPUs) 3.9Ghz
MOBO: Gigabyte
HDD: 1 (Drive C: 739GB free of 930GB)
2 (Drive F: 101GB free of 465GB)
RAM: HyperX 16gb
GPU: Nvidia 750Ti
PSU: Smart SE 530Watts
OS: Windows 10 (64bit)
hey dude
ive played this <Mod Edit> for 1.2K hours!
sometimes after some updates the fps would destroyed with literally no reason!
but if u have this issue for all of the time so tell me on what resolution you are playing this game? and on what graphic setting!
i guess the PC is doing well! just set the graphic config in some way that fps would be above the 60!
i used to play this game with gtx 950, on 1600x900 with ultimate graphic and i was getting something like 112 fps "average"
good luck
