Question Ctrl+Shift+N not working ?
Raceme007
42
My Windows 11 HP Pavilion 15 DK-20xx laptop has stopped creating a new folder when Ctrl+Shift+N is pressed. I have done no modification whatsoever.
I don't have a C-Media app installed. I tried different keyboard on different ports, uninstalling keyboard drivers.
When Ctrl+Shift+N is pressed, curser goes from "Normal Select" to "Working in Background" for a split second. But nothing happens.
How to fix this?
right click start button
choose terminal(Admin)
If it doesn't open as Powershell, click the drop down arrow in the title area and pick Powershell from list
copy/paste this command into window:
Repair-WindowsImage -Online -RestoreHealth
and press enter
Then type SFC /scannow
and press enter
Restart PC if SFC fixes any files as some fixes require a restart to be implemented
First command repairs the files SFC uses to clean files, and SFC fixes system files
SFC = System File Checker. First command runs DISM - https://docs.microsoft.com/en-us/windows-hardware/manufacture/desktop/what-is-dism?view=windows-11
if that doesn't help
Try a clean boot and see if it changes anything - make sure to read instructions and make sure NOT to disable any microsoft services or windows won't load right - https://support.microsoft.com/en-au/help/929135/how-to-perform-a-clean-boot-in-windows
It doesn’t delete anything, it just stops non Microsoft programs running with start. Easy to reverse.
if clean boot fixes it, it shows its likely a startup program. You should, over a number of startups. restart the programs you stopped to isolate the one that is to blame.
