Curious problem...
G
Guest
Guest
Archived from groups: alt.games.morrowind (More info?)
The last two times I've started the game, I have found myself with half the
screen filled with water. And as it changes as I go up or down in the
landscape it cannot simply be the flooding season...how do I fix this,
seeing how I just recently reinstalled the thing?(on a system unaware that
there had been any previous presences of it).
CAN I fix it?
Thanks either way,
Elfseeker@c2i.net
G
Guest
Guest
> CAN I fix it?
Well, that's a new one on me. Did you install the patch?
G
Guest
Guest
As I read it, it is one of these budget-things with all the neccessary
updates built into the basic installation...but give me the link to it, and
I'll give it a shot, see if it makes a difference(darn liers if it does, but
what else is new, eh? :p).
Elfseeker@c2i.net, feeling foolish... :)
G
Guest
Guest
Der? I'm not sure what you are talking about. Are you referring to the
Game Of The Year version?
Since you say you recently "reinstalled" it, I'm assuming you had it
running right at least once before this current install, yes? And since
you said that the problem occurred only on the last two times you
started the game, I'm assuming you possibly had the current version
running OK before that? Yes?
Have you recently added any new mods?
G
Guest
Guest
>CAN I fix it?
No matter where you are in morrowind, there's water drawn at a certain
level. Even if you would never normally see it, without turning off
clipping, and going wandering through walls.
Maybe your driver isn't correctly drawing the surface structures, letting
you see the water below? or maybe it's drawing the water level at the
wrong height?
Just a wild guess.
G
Guest
Guest
"Elfseeker" <elfseeker@c2i.net> ha scritto nel messaggio
news:fx7nc.81946$BD3.9962730@juliett.dax.net...
the
> CAN I fix it?
I have read there is a MOD (Seyda Neen Docks?, I don't remember) that lift
water level... have you Mods installed?
G
Guest
Guest
Not that I recall...They would in any case be most annoying if they managed
to exist apart from the main game...But no.
> wrong height?
Well, there is these white 'shadows' of plants and stuff overlaid over the
landscape where they are not...so it's most definately a
graphics-problem...I just can't understand of what sort...will try to switch
over to the other. Maybe that was what I was using last time, though I
severely doubt it. In would have installed the required DX if it wasn't
there, yes?
Yup. A-OK. messed myself as far along as to be running back and forth along
the ways in that multi-pyramidal place. A most tiresome affair, so I never
really finished it(that prison-cell impressed me, though. a comet prevented
from crashing...<g>).
I seem to recall I ran a reset of the system since then, and as the
'reset'-disc set thing up in an entirely different fashion(same Win-version,
though...I gather), it might be that some drivers got lost in the
process...hopefully my Hercules(or standard)-card can pull through,
somehow...if not, I'll anyway try to get a more useful one somewhere down
the road.
G
Guest
Guest
On Sat, 08 May 2004 16:03:23 GMT, "Elfseeker" <elfseeker@c2i.net>
>CAN I fix it?
>Thanks either way,
>Elfseeker@c2i.net
I had a similar problem. I fixed it by getting the updated
drivers for my graphics card. Might help for you.
G
Guest
Guest
>there, yes?
Sounds like you're in wire-frame mode. Do things look more solid the
further away they are? When you look at the ground do you see a dotty
white grid with water underneath? If you open the console (using the ~
key) and type TWF does anything change?
Greg Johnson
One tentacle, one vote.
G
Guest
Guest
Hm. indeed....though I got bad experiences with that, I'd be willing to try
again.
*heads on over to the 'hercules'-website*
