Hi everyone. I need some professional opinions from you as I am about to purchase some items for custom cable sleeving. This is going to be my first time so I am unsure if I had picked the correct items for the job.
I am planning to do a full length sleeving as I need to save some space for cable management. Cable extensions is simply not going to work for my rig.
For the psu I will use Rosewill 750w (https://www.newegg.com/global/ae-en/Product/Product.aspx?Item=N82E16817182323&Description=rosewill%20750w&cm_re=rosewill_750w-_-17-182-323-_-Product)
So now I am asking for your professional opinion regarding my items. As for the wire, I will use 16 gauge wire that I can purchase locally. I also have an ATX crimper and a heatgun.
By the way I am only planning to sleeve the main cables (24 pin, the cpu, and the gpu).
Thank you in advance.
