[SOLVED] Custom resolution/scale for a broken display
May 24, 2021
Hello.
I got an Lenovo V530 All in one pc with a broken display. In the bottom right corner I got a line of like 300x300 of dead pixels and the rest of the display is fine.
I'm looking on the internet for over 2 hours to find a solution to force a custom resoltuion/scale in order to avoid this side of my screen.
Is there any solution for running only a percentage of the display? I must specify that it is an intel gpu powered machine so no nvidia drivers.
Thanks.
I think the closest you got is split screen:
Except that, the OS tends to always try to utilize the whole monitor area, hence stretched image over cropped space.
So until you got a new monitor, manually resizing windows are probably the only viable option.
Thank you for your response, sadly I want to make it kind of a permanent solution, I mean not needing to set it up everytime I turn on the PC. This computer will be used by 2 emplyee girls who do not know complicated tricks in windows so I need something foolproof for the next 2-3 weeks until I get a replacement screen.
