[SOLVED] CyberPowerPC First Build
Aug 3, 2019
5
Hey Guys,
I am brand new to the forum and brand new to Gaming PC's as a whole. I am having my first PC built by CyberPowerPC. I would like to know from more experienced members if I got a semi decent deal. I opted for the Intel I9-9900k with the GeForce RTX 2080TI as my CPU/GPU. I ended up paying $2165 shipped. What do you all think on my specs/price? Also if you believe there are components I should add in the future please inform me! Again I am new to this and am excited to learn!
  • CAS: CyberPowerPC ELUNA 241V Premium RGB Gaming Case Mid-Tower w/ Tempered Glass Window Panel [-24] (Black Color)
  • CASUPGRADE: None
  • CC: None
  • CD: None
  • COOLANT: None
  • CPU: Intel® Core™ Processor i9-9900K 3.60GHZ 16MB Intel Smart Cache LGA1151
  • CS_FAN: 3X 120mm APEVIA 120mm Addressable RGB 1200RPM Fans w/ Hub + Remote Controller [+29]
  • ENGRAVING: None
  • EVGA_POWER: None
  • FA_HDD: None
  • FAN: CyberpowerPC MasterLiquid Lite 240mm ARGB CPU Liquid Cooler with Dual Chamber Pump & Copper Cold Plate (Intel) [+10]
  • HDD: 960GB ADATA SU630-960G SATA-III 6 Gb/s SSD - Seq R/W: Up to 520/500 MB/s, Rnd R/W up to 40/75k [-42] (Single Drive)
  • HDD2: None
  • HEADSET: None
  • IUSB: Built-in USB 2.0 Ports
  • KEYBOARD: CyberPowerPC RGB 7 Color Premium Gaming Keyboard
  • MEMORY: 16GB (8GBx2) DDR4/3200MHz Memory [-35] (ADATA Spectrix D80 RGB Hybrid Liquid Heatsink Cooling)
  • MICROPHONE: None
  • MONITOR: None
  • MOPAD: None
  • MOTHERBOARD: ASUS Prime Z390-P ATX w/ WiFi 802.11AC RGB, USB 3.1, 2 PCIe x16, 4 PCIe x1, 4 SATA3, 2 M.2 SATA/PCIe
  • MOUSE: CyberPowerPC Standard 4000 DPI with Weight System Optical Gaming Mouse
  • NETWORK: Onboard Gigabit LAN Network
  • OS: Windows 10 Home (64-bit Edition)
  • OVERCLOCK: No Overclocking
  • POWERSUPPLY: 800 Watts - Standard 80 Plus Gold Certified Power Supply [-63]
  • PRO_WIRING: None
  • PROJECTOR: None
  • PROMOSALE1: CyberPowerPC FPS Gaming Mouse Pad [+0]
  • RUSH: Standard processing time: ship within 5 to 10 Business Days
  • SERVICE: 3 Years FREE Service Plan (INCLUDES LABOR AND LIFETIME TECHNICAL SUPPORT)
  • SLI_BRIDGE: None
  • SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
  • SPEAKERS: None
  • TUNING: None
  • USBHD: None
  • USBX: None
  • VIDEO: GeForce RTX™ 2080 Ti 11GB GDDR6 (Turing) [VR Ready] (Single Card)
  • VIVE_HEADSET: None
  • WARRANTY: STANDARD WARRANTY: 1 Year Parts WARRANTY
  • WNC: None
  • WTV: None
*$2165 shipped
That is not a good motherboard for the 9900k, you want a higher end board with better power delivery, or go for the 9700k.
Agree you want a known high quality psu. 650w would be enough, a high quality 650w will be better than a low quality 800w.
The 9900k is a hot cpu, I’d go for a cooler like the Corsair 115i. When running a high end system like this cooling and psu quality are very important.
Hey Guys,
  • CASUPGRADE: None
  • CC: None
  • CD: None
  • COOLANT: None
  • ENGRAVING: None
  • EVGA_POWER: None
  • FA_HDD: None
  • HDD2: None
  • HEADSET: None
  • MICROPHONE: None
  • MONITOR: None
  • MOPAD: None
  • PRO_WIRING: None
  • PROJECTOR: None
  • SLI_BRIDGE: None
  • SPEAKERS: None
  • TUNING: None
  • USBHD: None
  • USBX: None
  • WNC: None
  • WTV: None
*$2165 shipped
Perhaps a bigger hard drive in addition to the SSD 1tb goes pretty quick these days. All in all not a bad price.
Hey thank you for your help! I ended up canceling my order. I changed my PSU to a 750 Watts - GIGABYTE G750H 80 Plus Gold Semi-Modular w/ Double Ball Bearing Fan Power Supply. And also upgraded my MB to a ASRock Z390 Taichi w/ 802.11ac Wi-Fi, ARGB, USB 3.1, 3 PCIe x16, 2 PCIe x1, 6 SATA3, 3 M.2 SATA/PCIe. Added a better liquid cooling fan as well. With CYBERPOWERPC specials today only cost an extra $112 with 3 day shipping!
$2,000 and a single 1TB SATA II SSD?
Major fail.
LOL. I'm trying to be cost effective as possible. I reordered my configuration. With the new order. I upgraded my MB to a Z390 Taichi, upgraded my PSU to a Gigabyte G750H 80 Plus Gold Semi-Modular w/ Double Ball Bearing Fan. A 360MM liquid cooling fan. And changed my HD configuration to 3TB (3TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD and 512GB Intel® 660P SERIES PCIe NVMe M.2 SSD - Seq R/W: Up to 1500/1000 MB/s, Rnd R/W up to 90/220k. Ill upgrade to more SSD memory in the future.
