Daredevil me.. Need a watercooling solution in the 250d
aarnav
93
Hello...
Fed up of the r9 290 in my mini itx making tons of noise and sound I decided to go for a loop... I know its hard but not impossible..The obsidian 250d is pretty spacious.. I only need to cool my gpu for now... I have the asus directx cu ii
Well my budget is around 200 dollars....
Thx
Yes, get those heatsinks, the spot cool, the Kraken and CPU cooler that will work with the kraken, then it will stay frosty.
Kraken g10. Look it up, its from NZXT - 30 bucks
Corsair h series AIO cooler or another one of choice(CHECK ON THE NZXT SITE IF THE AIO WILL WORK, THEY HAVE A PART CHECKER.) - 120 bucks at most
Total: 150 USD
EDIT: THESE ARE THE COOLERS THAT WILL WORK THIS THE KRAKEN G10 COVER.
NZXT : Kraken X60, Kraken X40
Corsair : H105, H110, H90, H75, H55 , H50
Antec : KUHLER H2O 920V4, KUHLER H2O 620V4, KUHLER H2O 920, KUHLER H2O 620
Thermaltake : Water 3.0 Extreme, Water 3.0 Pro, Water 3.0 Performer, Water 2.0 Extreme, Water 2.0 Pro, Water 2.0 Performer
Zalman : LQ-320, LQ-315, LQ-310
Now cross-check with your case,
