[SOLVED] DDR for P5Q Pro
May 6, 2021
Hi
I want to upgrade my RAM from 4GB to 8GB. Which memory from these will be best for P5Q Pro with Xeon X5460?
Corsair CM2X2048-6400C5C v4.3
Corsair CM2X2G6400C4DHX v1.1
Adata ADQVD1B16
Kingston KHX6400D2B1K2/4G
I dont think so. Now my cpu is running 9.5x400 wich gives stable 3.8GHz.
Then any of them should work and I stand by my recommendation of the first or last.
At those speeds though, if you can OC the ram, you would benefit from it. There were pc2-8500 (1066) kits available back in the day (and higher), but they're expensive now due to their rarity.
