[SOLVED] DDU freezes while running ?
Jan 29, 2022
DDU freezes while running.
i run DDU to remove my gtx 1060 3gb driver. But then i realize it's frozen and I cant move the mouse cursor. I ran it at safe mode also (I watch Jayztwocents turorial) but then I realized it’s a couple of hrs. Is it safe to shut down the system and turn it on again ?
DDU shouldn't freeze?
that is a new one.
I expect restarting PC would work.
Did you try doing a clean install of drivers through geforce experience?
when you run the app, and have downloaded a driver, pick Custom install and on the next screen, there should be an option at bottom to clean install drivers. this will remove them all and put the drivers for card back on.
that is a new one.
