Decent specs to play DayZ Standalone? Help
Adaammm
12
I made this build and was wondering if it was any good for playing DayZ Standalone at around medium settings with more than 30fps.
It has an APU, which I know is not the best for gaming but from what i have heard, this one is alright.
The motherboard allows me to upgrade to a dedicated GPU at a later time.
This is my first proper gaming PC and my budget is not high, could you tell me if this is good? And if you want to try build one for me, my budget is £360!
http://uk.pcpartpicker.com/p/3DMvL
I would just upgrade to the newer APU:
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor (£119.99 @ Aria PC)
Motherboard: Gigabyte GA-F2A88XM-D3H Micro ATX FM2+ Motherboard (£48.63 @ Ebuyer)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory (£62.90 @ Aria PC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£41.82 @ Aria PC)
Case: Thermaltake Commander MS/I Snow Edition (White/Black) ATX Mid Tower Case (£34.56 @ CCL Computers)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply (£35.76 @ Amazon UK)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer (£11.79 @ Amazon UK)
Wireless Network Adapter: TP-Link TL-WN722N 802.11b/g/n USB 2.0 Wi-Fi Adapter (£7.01 @ Aria PC)
Total: £362.46
(Generated by PCPartPicker 2014-05-05 12:38 BST+0100)
Everything else looks fine. That PSU isn't the best quality but at this budget you don't have many other options.
I personally like the build, and it should definitely play DayZ Standalone at decent settings.
Dayz Requirement:
Minimum:
OS: Windows Vista SP2 or Windows 7 SP1
Processor: Intel Dual-Core 2.4 GHz or AMD Dual-Core Athlon 2.5 GHz
Memory: 2 GB RAM
Graphics: NVIDIA GeForce 8800GT or AMD Radeon HD 3830 or Intel HD Graphics 4000 with 512 MB VRAM
DirectX: Version 9.0c
Hard Drive: 10 GB available space
Sound Card: DirectX®-compatible
Recommended:
OS: Windows 7 SP1
Processor: Intel Core i5-2300 or AMD Phenom II X4 940 or better
Memory: 4 GB RAM
Graphics: NVIDIA GeForce GTX 560 or AMD Radeon HD 7750 with 1 GB VRAM or better
Hard Drive: 14 GB available space
CPU: Intel Pentium G3220 3.0GHz Dual-Core Processor (£37.80 @ Aria PC)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard (£30.90 @ CCL Computers)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory (£57.46 @ Ebuyer)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£39.50 @ Amazon UK)
Video Card: Sapphire Radeon R7 265 2GB Video Card (£113.00 @ Ebuyer)
Case: BitFenix Comrade ATX Mid Tower Case (£28.04 @ Aria PC)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply (£45.98 @ Dabs)
Total: £364.47
(Generated by PCPartPicker 2014-05-24 07:22 BST+0100)
This is what I'd get :)
