EDIT: I found the answer to all my questions , I dont know how to close this post.
I posted this on other forum, but I did not receive a reply yet, and as I need some help ASAP, I also post it here.
So I want to connect 4 120 ML fans(case) + 2 ML fans (H100i) + case RGB logo. I found this image on the forum, its pretty similar to what I want to do, so here I have a few questions.
1) Instead of 6 120ML fans to the RGB hub, can I connect 4 case fans and the RGB logo of the case? or it would be like connecting two different type of fans and wouldnt work? If so, can I connect the logo to one of the two RGB connections on the commander pro? instead of RGB strips like in the picture? or do I need another RGB Hub just to connect the logo.
2) Im also connecting a H100i with 2 120ML fans, connecting these two RGB fans to the pump. Will I still be able to sync the H100 fans RGB with the RGb fans connected to the RGB hub? (Using link/icue)
3) If instead of the commander pro, I use any other PWM fan Hub controller, will I still be able to connect the RGB hub to "random PWM fan controller" and still be capable of using icue?
4) If I connect 120ML fans to the RGB hub, can I use iCue? do I need a commander pro to use iCue?
Thank you for your time.
EDIT: Now I see I need the commander PRO because the RGB hub can not be connected to the motherboard via USB, am I right? still would like to confirm if I can use any other PWM, or I must use the commander pro to be able to use iCue.
