Dell Dimension 9200 won't start - diagnostic lights 2 and 4
dannyc75
My Dell Dimension 9200 won't start and I get the diagnostic lights 2 and 4. I get lights 1, 3 and 4 on startup, with no beeps, then the fan sounds like it's about to take off and I get lights 2 and 4. The PC manual says lights 2 and 4 means a problem with the graphics card - in my case an NVIDIA GeForce 8600 GTS. I've tried reseating the card but this makes no difference - I've also tried reseating the memory cards, removing dust and clearing the CMOS but I still can't get my PC to start.
Before I buy a new graphics card, I just wondered if anyone knew of anything else that might be causing the problem?
Many thanks
It was the graphics card - I replaced with a Radeon HD7500 and the PC works perfectly again. Noticed when I was taking out the old graphics card that the fan was clogged up with dust so I imagine it must have overheated one two many times...
Having the same problem on Dell 9100 with the same video card that I installed about 2 weeks ago now. Things worked fine until yesterday and upon trying to start it would appear to try to go to Bios? but something was failing. A workaround to this was flipping the orange switch on my power box inside the tower, from 115 to 230 (IIRC). It would then boot normally without any problems. Today upon trying to start it, it would do as Dannyc75's would, the fan would spin up higher than normally, no video output would be given, and changing the power wattage? switch would yield no change. My 8600 gts has been kept very clean over the years and has served well, in addition to being practically spotless before installation 2 weeks ago. Bios lights 2 and 4 are on also. Is my GPU dead? If I get it to boot in the mean time, should I run it normally? If that occurs I will post DXdiag.
Any help is greatly appreciated? :/
Here is my aforementioned DXdiag. I installed the Radeon card from a pc just received from a neighborly friend, but as you can see the 8600gts is much preferred, would like to keep that if possible.
System Information
Time of this report: 6/4/2014, 15:18:54
Machine name: LEMANRUSS
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.140303-2144)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Dimension 9100
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A01
Processor: Intel(R) Pentium(R) D CPU 3.00GHz (2 CPUs), ~3.0GHz
Memory: 2048MB RAM
Available OS Memory: 2046MB RAM
Page File: 1569MB used, 2522MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Radeon X300/X550/X1050 Series (Microsoft Corporation - WDDM)
Manufacturer: ATI Technologies Inc.
Chip type: ATI Radeon Graphics Processor (0x5B60)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_5B60&SUBSYS_06021002&REV_00
Display Memory: 798 MB
Dedicated Memory: 31 MB
Shared Memory: 767 MB
Current Mode: 1920 x 1200 (32 bit) (59Hz)
Monitor Name: Dell 2407WFP-HC (Digital)
Monitor Model: DELL2407WFPHC
Monitor Id: DELA026
Native Mode: 1920 x 1200(p) (59.950Hz)
Output Type: DVI
Driver Name: atiumdag,atiumdva,atiumd64.dll,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.14.0010.0630 (English)
Driver Version: 8.56.1.16
DDI Version: 9Ex
Driver Model: WDDM 1.0
Driver Attributes: Final Retail
Driver Date/Size: 7/13/2009 18:40:03, 4030976 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71EE2-1820-11CF-C471-0826A1C2C535}
Vendor ID: 0x1002
Device ID: 0x5B60
SubSys ID: 0x06021002
Revision ID: 0x0000
Driver Strong Name: atiilhag.inf:ATI.Mfg.NTamd64...1:ati2mtag_RV370:8.56.1.16😛ci\ven_1002&dev_5b60
Rank Of Driver: 00F42001
Video Accel: ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Creative SB Audigy 2 ZS (WDM))
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0004&SUBSYS_20061102&REV_04
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 6.00.0001.1241 (English)
WHQL Logo'd: Yes
Date and Size: 4/10/2007 04:35:28, 863016 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: SPDIF Out (Creative SB Audigy 2 ZS (WDM))
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (Creative SB Audigy 2 ZS (WDM))
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: CD Digital (Creative SB Audigy 2 ZS (WDM))
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
Description: S/PDIF-In (Creative SB Audigy 2 ZS (WDM))
Cap Flags: 0x1
Description: Analog Mix (Line/CD/Aux/TAD/PC) (Creative SB Audigy 2 ZS (WDM))
Cap Flags: 0x1
Description: "What U Hear" (Creative SB Audigy 2 ZS (WDM))
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x27CA
| Matching Device ID: usb\root_hub
| Service: usbhub
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Vendor/Product ID: 0x413C, 0x2003
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ HID-compliant mouse
| Vendor/Product ID: 0x413C, 0x3200
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 145.6 GB
Total Space: 238.4 GB
File System: NTFS
Model: WDC WD2500AAJB-00WGA0 ATA Device
System Devices
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D0
Device ID: PCI\VEN_8086&DEV_27D0&SUBSYS_00000000&REV_01\3&172E68DD&0&E0
Driver: n/a
Name: Intel(R) 945G/GZ/GC/P/PL PCI Express Root Port - 2771
Device ID: PCI\VEN_8086&DEV_2771&SUBSYS_00008086&REV_00\3&172E68DD&0&08
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
Device ID: PCI\VEN_8086&DEV_27CC&SUBSYS_01A71028&REV_01\3&172E68DD&0&EF
Driver: n/a
Name: Intel(R) 945G/GZ/GC/P/PL Processor to I/O Controller - 2770
Device ID: PCI\VEN_8086&DEV_2770&SUBSYS_01A71028&REV_00\3&172E68DD&0&00
Driver: n/a
Name: Radeon X300/X550/X1050 Series Secondary (Microsoft Corporation - WDDM)
Device ID: PCI\VEN_1002&DEV_5B70&SUBSYS_06031002&REV_00\4&26C98DFD&0&0108
Driver: n/a
Name: Intel(R) 82801GR/GH/GHM (ICH7 Family) PCI Express Root Port - 27E2
Device ID: PCI\VEN_8086&DEV_27E2&SUBSYS_00000000&REV_01\3&172E68DD&0&E5
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
Device ID: PCI\VEN_8086&DEV_27CB&SUBSYS_01A71028&REV_01\3&172E68DD&0&EB
Driver: n/a
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_E1\3&172E68DD&0&F0
Driver: n/a
Name: Intel(R) 82801GR/GH/GHM (ICH7 Family) PCI Express Root Port - 27E0
Device ID: PCI\VEN_8086&DEV_27E0&SUBSYS_00000000&REV_01\3&172E68DD&0&E4
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
Device ID: PCI\VEN_8086&DEV_27CA&SUBSYS_01A71028&REV_01\3&172E68DD&0&EA
Driver: n/a
Device ID: PCI\VEN_8086&DEV_1080&SUBSYS_10001028&REV_04\4&5855BE9&0&28F0
Driver: n/a
Name: Radeon X300/X550/X1050 Series (Microsoft Corporation - WDDM)
Device ID: PCI\VEN_1002&DEV_5B60&SUBSYS_06021002&REV_00\4&26C98DFD&0&0008
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
Device ID: PCI\VEN_8086&DEV_27DF&SUBSYS_01A71028&REV_01\3&172E68DD&0&F9
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
Device ID: PCI\VEN_8086&DEV_27C9&SUBSYS_01A71028&REV_01\3&172E68DD&0&E9
Driver: n/a
Name: PCI Input Device
Device ID: PCI\VEN_1102&DEV_7003&SUBSYS_00401102&REV_04\4&5855BE9&0&21F0
Driver: n/a
Name: Intel(R) PRO/100 VE Network Connection
Device ID: PCI\VEN_8086&DEV_27DC&SUBSYS_01A71028&REV_01\4&5855BE9&0&40F0
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
Device ID: PCI\VEN_8086&DEV_27C8&SUBSYS_01A71028&REV_01\3&172E68DD&0&E8
Driver: n/a
Name: 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1102&DEV_4001&SUBSYS_00101102&REV_04\4&5855BE9&0&22F0
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) SMBus Controller - 27DA
Device ID: PCI\VEN_8086&DEV_27DA&SUBSYS_01A71028&REV_01\3&172E68DD&0&FB
Driver: n/a
Name: Standard AHCI 1.0 Serial ATA Controller
Device ID: PCI\VEN_8086&DEV_27C1&SUBSYS_01A71028&REV_01\3&172E68DD&0&FA
Driver: n/a
Name: Creative SB Audigy 2 ZS (WDM)
Device ID: PCI\VEN_1102&DEV_0004&SUBSYS_20061102&REV_04\4&5855BE9&0&20F0
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_27D8&SUBSYS_01A71028&REV_01\3&172E68DD&0&D8
Driver: n/a
Name: Intel(R) 82801GB/GR (ICH7 Family) LPC Interface Controller - 27B8
Device ID: PCI\VEN_8086&DEV_27B8&SUBSYS_00000000&REV_01\3&172E68DD&0&F8
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.18221
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9200.16426
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17835
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17835
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17835
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.18386
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.18386
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17835
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
Audio Capture Sources:
Microphone (Creative SB Audigy ,0x00200000,0,0,qcap.dll,6.06.7601.17514
"What U Hear" (Creative SB Audi,0x00200000,0,0,qcap.dll,6.06.7601.17514
Analog Mix (Line/CD/Aux/TAD/PC),0x00200000,0,0,qcap.dll,6.06.7601.17514
CD Digital (Creative SB Audigy ,0x00200000,0,0,qcap.dll,6.06.7601.17514
S/PDIF-In (Creative SB Audigy 2,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
SB Audigy 2 ZS MIDI IO [C880],0x00200000,1,0,quartz.dll,6.06.7601.17713
SB Audigy 2 ZS Synth A [C880],0x00200000,1,0,quartz.dll,6.06.7601.17713
SB Audigy 2 ZS Synth B [C880],0x00200000,1,0,quartz.dll,6.06.7601.17713
WDM Streaming Capture Devices:
,0x00000000,0,0,,
SB Audigy 2 ZS MIDI IO [C880],0x00200000,2,2,ksproxy.ax,6.01.7601.17514
SB Audigy 2 ZS Audio [C880],0x00200000,2,2,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
SB Audigy 2 ZS DirectMusic Synthesizer [C880],0x00200000,1,1,ksproxy.ax,6.01.7601.17514
SB Live!2K Audio [C880],0x00200000,1,1,ksproxy.ax,6.01.7601.17514
SB Audigy 2 ZS Synth A [C880],0x00200000,1,1,ksproxy.ax,6.01.7601.17514
SB Audigy 2 ZS Synth B [C880],0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Creative SB Audigy 2 ,0x00200000,1,0,quartz.dll,6.06.7601.17713
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: SPDIF Out (Creative SB Audigy 2 ZS (WDM)),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (Creative SB Audigy 2 ZS (WDM)),0x00200000,1,0,quartz.dll,6.06.7601.17713
SPDIF Out (Creative SB Audigy 2,0x00200000,1,0,quartz.dll,6.06.7601.17713
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Its likely you will need to replace that card also that can damage your computer and I do not recommed useing that to get your computer to start also have you tried removing the card and trying to boot?
I switched back to the card i was using before hand, replaced the nvidia 8600gts into the other desktop tower#2 i have, which runs flawlessly. Tower #1 works fine now but if there is a way to use the nvidia card in tower#1 that would be greatly preferred to the ancient radeon currently being used.
Latest posts
