Dell inspiron 560 Graphic card help!!
dulans
13
Hi guys,
Can someone tell me the diff#t btwn
1. ASUS AMD Radeon HD 6670 PCI-E Graphics Card - 2 GB -- £69.99
2. VTX 3D AMD Radeon HD 6670 PCI-E Graphics Card - 2 GB -- £49.99
Im confused. Wanna upgrade my Dell inspiron 560. It has a 300W PSU. Help me pls.
Thanks in advance.
Euh . . . that they both probably don't need or use the 2G.
Asus is a better brand maybe than VTX. Bigger anyway i suspect, till now i've only seen them in the UK.
What are you gonna do with the card ? Gaming ? Also whats your budget ?
Thanks for quick reply robjordy !!
Budget is abt £80. But not sure which one to select. Coz my psu is 300w. I read on Google that radon 6670 will work on this. Also I'm experimental user. Wanna try installing MAC on this. Also most importantly I need to run Adobe Photoshop CS 5.
Any recommendations?
I checked mu mobo and its PCI-e Gen 2. So would HD7750 will work you think? price would be manageable. I would like a high end card but with my PSU. I dont wanna change psu though...
