Hey guy's I really do not like dell or there products and do not own one or know anyone who have had good luck with there service techs.
Which is why my niece brought her problem to uncle, her monitor when starting up does the startup just fine and dandy. But after two seconds it literally goes completely black, no faded gray images, just black!
The monitor came with a Dimension E510. I assume it is a typical dell package, it is a 17in. LCD monitor model # 1707FPc
OK so I have so far deduced that it is indeed the monitor and not the energy saving mode from the PC I have tryed out on a different system and it does the no good I have hooked my own monitor to my niece's system and my monitor works good with her system so... when starting up I have gone into the menu after a hundred restarting of the monitor 🙁 I seen a factory reset to factory settings not sure whats going on after it is highlighted because of the blacking out I can toggle to it but then black screen kicks in (@%#%@$) motherfu....r is really pissing me off.
Ok there are 5 function button on this monitor left to right, leftside the firt button a box with an arrow pointing into the center of the box, the second button is the menu button, third button is a menus "-" sign, fourth button is a plus "+" button and the last button on the rightside is the on-off button.
After I highlighting the reset factory setting option which button actually enables this function? Because it goes black I do not know if another option or whatever needs to be done it is not on the screen so I'm hoping someone who has had the same problem knows or can help me or someone has the same monitor can they please tell me what comes up and what button actually enables the command to reset.
FYI I have done the disconnect the monitor and turned it on to do a dignostic check AGAIN DID I TELL YOU THE MOTHERF....R goes black after 2 flipping sec. again same problem see it can't react fast enough to see what is actually going on and if I need to do anything else HELP PLEASE!
