This is split from another question I asked here on this post.
To summarize, I have a Dell monitor that is very picky about detecting input sources. Looking back, I've had this problem for as long as I remember, when I used to have trouble connecting my macbook to it as an external display, but I thought it was an issue with the adapter I used to connect HDMI. Now however, I notice it even more after getting a PC and not being able to display anything.
Some important Specs:
- Monitor: Dell 2721HGF (144Hz Monitor)
- Motherboard: MSI B250 PC Mate
- Processor: Intel i7 6700
- GPU: MSI Nvidia GTX 1050 2G/Sapphire Nitro AMD Radeon RX 580 8G
I got a used PC that had a GTX 1050 and I was able to boot it up just fine. However, the monitor wasn't able to detect the integrated graphics, which initially I thought was because the processor had no iGPU or something. It didn't bother me since I tested using the 1050 anyway and upgraded to an RX580 shortly after. I had trouble at first trying to set up the RX580 because nothing displayed either, which I worked around by connecting both the 1050 and RX580 and installing the AMD drivers while the HDMI was connected to the 1050.
Thought it was a GPU issue that I wasn't able to boot into BIOS (boot straight to windows), but after days of troubleshooting, it turned out the monitor was the problem. I was able to access BIOS and the boot menu when I connected the HDMI to an small 60Hz TV I had lying around. I was also able to access BIOS and use the iGPU as long as I first boot into either one connected to the TV, and then switch it to the monitor after. This is pissing me off because the only way for me to say dual boot to Linux is for me to connect to the TV first, and then switch the display the monitor once I've left the boot menu. But every single time I spam the BIOS button, the monitor doesn't detect a display and just immediately goes to standby without a countdown.
I'm so lost. Is there some way to troubleshoot the monitor itself? It doesn't look like there's alot possible to do after looking through the manuals and everything.
