Question Dell optiplex 390 sff case swap and add a graphics card
May 8, 2024
5
I have an optiplex 390 sff and I want to change its case to add a graphics card.
What problems will I have when making the change?
What graphics card do you recommend?
Optiplex 390 sff
i5-2400
8gb ram ddr3 1333 mhz
SSD 250 gb
1| Front panel connectivity but you can avert that with this;
https://www.amazon.com/Front-Panel-Header-Adapter-Optiplex/dp/B0BWMZSPBY?th=1
2| The form factor to the motherboard is proprietary, even though the connectors on the board are standard, the board's size isn't.
In 2024 for that platform, nothing. Save up the money and build an entry level system with concurrentparts and with the avenue to upgrade later down the road as opposed to dropping money on a decade old platform with no upgrade potential. Even if it was upgraded with yesteryears hardware, you're not gaining much for the moeny spent.
It doesn't even have Windows 11 support while Windows 10 will be a decade old in 1 years time.
What is the cheapest and most upgradable currently?
